MTS1200 2014MY Am wanting to bleed the braking system and insert bleed nipples next to the ABS unit I have read that I need to cycle the ABS unit but no idea how to Would like to do a full fluid change inc the fluid in the ABS circuit / pump?
There is a small chance of air trapped in the ABS mechanism after bleeding. The recommendation I have read is to cause the ABS to actuate obviously somewhere safe with a good road surface. The air bleed mod on the actuator block has advocates and the only issue I have heard of is the bleed nipple pushes into the under side of the seat. Andy
