1200 S Adjustable Suspension
Discussion in 'Monster' started by Davkyt, Mar 4, 2018.
  1. Adjusting suspension
    1200s...
    It seems that it was all set up for super comfort so I should feel a difference the next time I go out.... Assuming my understanding is right....
    The preload on the front it (the book) says 10 turns for standard... Is that 10 anticlockwise turns? From the full clockwise position?
    And...(this might sound silly) The rebound on the rear... Is clockwise the same way as the compression? As though your looking at it from the rear?
    Also, I'm only 67ish kg.... So should I do a couple of clicks less to achieve "standard" set up?.... The books standard settings is for a 80/90kg rider
  2. Is that 67kg in all your gear ?
  3. No, I realised that after I posted
  4. If you're not experienced with suspension adjustment it will pay you to get it adjusted professionally. Cost about £50 and will transform the bike. Properly adjusted suspension will increase your confidence and make you smoother which is also quicker. One of the best mods you will ever do to the bike.
