I've got short levers on my bike and whilst the brake is spot on, the clutch is too short for my liking. I loosened the bracket on the handlebar to see if it was possible to adjust it but there appears to be a retaining pin on the handlebar holding it in position. Can I remove the pin and adjust it or am I better off not messing around with it?
I just pulled mine out with some needle nosed pliers because I had the same issue. Just takes some working but it'll pop out! Sent from my iPhone using Tapatalk
As DanABZ said, the pin can be removed. I tried very short levers on a previous 1098 and the clutch was too short. I am now using Rizoma levers which are shorter than OEM but not as short as levers like ASV.
