After Market Throttle For 748,916,996,998
Discussion in 'Ducati General Discussion' started by Skidmark66, Feb 12, 2015.
  1. Can someone recommend one please. I have purchased an aftermarket Accossato front brake MC and using the standard throttle set up is a bit of a squeeze around the bleed nipple.
    Mark.
  2. keep the original and drill a new anchor hole for it after rotating the grip around to clear the bleed screw.
  3. Rotate the throttle housing
  4. Yep will do this if I cant find another.
  5. All sorted now thanks.
