Anodise
Discussion in 'Lounge' started by Ballbagracer, Sep 29, 2013.
  1. Can you have something re anodised?
  2. Yes you can, but sometimes the surface finish suffers, may need adjusting (polishing)
  3. Thank you gents. (A simply question for a simple guy)
  4. yes you can and it isn't to expensive as well.
    henk!!!
  5. Yes you can but . The more you do the more honeycombed the metal becomes and I think it possibly is not so good or can effect the surface of the metal as the acid used obviously removes a small amount each time you do it .. So say if you kept re anodising a fork tube I'm sure I was shown one and each time it was done got thinner and thinner ...
