1200 Anyone Fitted A Kriega Tank Adapter To The Multi?
Discussion in 'Multistrada' started by Dr Mark, Jul 21, 2014.
  1. Has anyone fitted a Kriega tank adapter to their Multistrada?
    I was going to fit mine this evening but I was a little concerned the front straps that generally fit to the radiator mounts ( on previous bikes) will chaff all those very important electric cables that are tucked away either side of the headstock !
    Any thoughts?
  2. The front straps loop through the top of the frame tubes that are just forward of the tank-down in the gap on the inside of the plastic of the cockpit.
    Bloody fiddly to get to I know. Best if plastic & tank removed. Ensure they are under the wiring, not over any wiring. I leave mine there when the bag is off and just thread them over and over the frame tube, again, under the wiring. Works fine.
  3. yep been using one for years great piece of kit . just loop it through the front as above very easy
