Back arrows not working
Discussion in 'Suggestions & Feedback' started by catweazle, Jun 21, 2012.
  1. Rob when I select the back arrow to come out of a subsection of the forum there is no action, at the moment to to get back to the forum I have to select forum, I have shut down and reloaded and still get the same response, is there an issue with the control buttons at your end or do I have a problem?
  2. No problems here, everything is A-Ok.
    A lean, mean, forum machine :smile:.
  3. Hi catweazle,
    No problem my end. Can you click on the forum logo, or ‘Forum’ tab to bring you back?
  4. Clicking on the forum tab brings me back up to the main forum its not a problem just a change in function. I will do a spring clean and shut down and then restart to see if that makes a difference.
  5. Did a house clean and its back to normal no idea what was causing it just thought you could do with a challenge, thanks and keep up the good work.
