899 Bar End Removal
Discussion in 'Panigale' started by camelfarmer, Nov 26, 2016.
  1. Does anyone know what tool is best for removing the bar ends - to change the grips and put different bar ends on.
    From googling it seems to be either a 12mm hex (allen) or a triple square M14. Someone mentioned a T60 torx and someone else said it didn't work.
    Anyone done this already and know the correct tool?
  2. I used a T?? Torx bit on mine (1299) and it came off as easily as anything.
  3. LoL
    This is weird as I've literally just got in from the garage from taking mine off to fit new grips
    I used an Allen key. Works fine, put a thin cloth over the end of it to avoid any scratching.
  4. Interesting.
    Hmm I don't have a 12mm allen key, so I wonder if I should spend money on that or money on a xzn (triple square) M14...
    I assume it was a 12mm you used?
    #4 camelfarmer, Nov 26, 2016
  5. Just checked. It was the T60 you mentioned that I used. Worked a treat.
