V4 Best Method To Fit Frame Guards.
Discussion in 'Panigale' started by JamOnIt, Dec 7, 2020.
  1. Good morning,
    I’ve ordered the fullsix carbon fibre frame guards but have been told they don’t come with a fitting kit.
    So any tips on fitting frame guards, do I use double sided tape, a silicone adhesive over heat resistant foil on the frame?
    Looking forward to hearing from people that have already fitted these successfully.
    Regards.
  2. Bathroom sealant or similar does a good job and comes off when you want it to.
  3. My ilmberger ones came with double sided tape and are on pretty firmly.
  4. Yep as above with mine ilmberger with double sided. No issues and a snug fit. Just use some brake cleaner to remove any surface grime and warm up both surface areas with a hairdryer....
