the bleed nipple on my clutch slave cylinder is corroded and when I tried to bleed it the fluid didnt come out of the nipple, can anyone point me in the direction of where to get a generic replacement? cheers
If u manager to get out cleanly good chance u will be able to clean it with a needle or similar but if it's knocked up can get them on ebay Sent from my SM-T580 using Tapatalk
Might be easier to order a Ducati one, or try Venhill? Venhill.co.uk Motorcycle Braided Brake Hoses, Lines and Clutch Cables
Not sure of the size but as twin4me suggested you local dealer would be a good bet. They should only be a few pence. Sent from my SM-T580 using Tapatalk
Or your local motor factors they keep selection boxes of them normally. Sent from my SM-T580 using Tapatalk
