V4 Bonamici Rearsets
Discussion in 'Panigale' started by Perc, Aug 12, 2018.
Tags:
  1. I have them on mine, not tried them out yet - will be finding out on Tuesday at Donny.
    Fitment wise, it was ok - not sure if there is a slight issue on the link rod as it won't screw in as far as the original one. Therefore had to adjust the pivot arm which was a pita to undo.
    Lookwise, fantastic.
  2. Great! Keep me posted on what your thoughts are after Donny
    Cheers
  3. oK, just a bit of an update.
    Rearsets work well - if you didn't want to adjust the pivot arm - just order another shorter link rod - another v4 owner did just that.
    They were grippy and comfortable, however rear brake doesn't work that well. On the road its fine - but on the track, there is a lot of spongy travel before brakes come on.
    I got them for 570gbp shipped from Italy and will recommend.
  4. Thanks for the update.
    I've seem them advertised on ebay (Italy) for less than the ebay uk site, here: https://www.ebay.it/itm/PEDANE-ARRE...736342?hash=item5d7f5ca456:g:QywAAOSwIphbTZXY
    Interesting point on the rear brake, is the leverage different?
    Cheers P.
