hi, seen a few modded bottom yokes for sale that allow you to use a headstock stand thru it. any idea's exactly what has been done to these, is it just a case of drilling the right sized hole? (want to be able to use the same stand for Duke and Gixxer)
As above, yes just need to drill a hole in the bottom yoke - there is a drain hole which is not central so don't use it as a guide! I would advise removing it to drill rather than use a hand drill lying down under the front end. Some aftermarket yokes (Ohlins) are bored right through - be aware that the ID of the stem is quite large (28mm IIRC) and so if you drill the yoke out fully you'll need a big pin for your stand.
Buy one of these and then never have to worry about it. Stand is not cheap but made to last a life time. FS11/D Motorcycle Front (headstock) Paddock Stand
The best way. FYI the bottom yoke without stem looks like this; See how the drain hole is to the rear Ohlins yoke is already through bored;
Looks like a worthy mod. I've had a few 'moments' with the under caliper ones, especially with the wheel out! :Arghh:
Makes things like adjusting fork height, changing clipons and the like really easy with headstock lift. A must imo for track/race bike
If you have access to or know someone who can weld, you could make a plate with the ends bent up that "cups" the underside of the yoke and weld on a suitable adapter ring to suit the pin of the stand you want to use.
I have carried this mod out to my yokes . Very, very easy to drill with a battery hand drill as the cast ali material is very soft. Start small, then worked up to 15mm reduced shank drill...
If you have a stepped or cone drill as they are known, that is the easiest method of slowly opening up a hole to get the right size.
