Hi guys, I was wondering if anyone had fitted aftermarket braided hoses to their Multi. I'm talking single lines to the front via an extended banjo connector at the master cylinder. I think one to the rear may improve rear braking performance too. Can't remember ever seeing any kits available from HEL or Goodridge - anyone know if they're available? Cheers
Stock lines are braided. Other than cosmetics, there's no advantage. If you have the ABS equipped bike, then a two line front won't work as you've got to go to the ABS pump first.
If you check on threads about Brembo M4 callipers there is conversations about doing this, Venhill can make up the right lines.
