748 Brake Fluid Dot 5
Discussion in '748 / 916 / 996 / 998' started by Pidge1969, Aug 16, 2016.
  1. I'm about to do the clutch and brake fluid and have been told DOT 5 is the way forward, can anyone tell me if DOT 5 is better just for longevity? I thought DOT 4 was the way to go but once again if people have experience of or can enlighten me further then that would be great.
  2. you probably want DOT 5.1
    DOT 5 cannot be mixed with any other DOT fluid.
    You probably won't notice any difference between 4 and 5.1 though it may prevent brake fade on track.
  3. As above, 4 or 5.1. Not 5.
  4. Dot 5 is also really hydrascopic (absorbers moisture) not ideal for road
  5. Cheers all for your comments will get some 5.1 and give it a go.
  6. Castrol Dot 4 for me
