Breaking 998 track bike
Discussion in 'Parts, Accessories & Clothing For Sale' started by labinx, Oct 16, 2012.
  1. Hi All
    So with the track day season coming to an end I thought I would strip down my 998 and give everything a good clean & check over, bearing & seals etc. Stripping it all down & taking lots of photos so I know where everything goes & routed, on removed the engine from the frame by myself, (Yes a know!!!) the F@#king engine slipped out of my hands!!, thought I got away with it until the next day when I went in to the garage and there was a pool of oil under the engine. One of the half crank cases has got a crack in it great!!!!
    I started to try to repair it with some alloy resin when some 998 crank cases came available on Ebay. I bought them and stripped the engine down with the intension of replacing the cranked crack case and rebuilding it.
    But with just starting a new job, I just don’t have the time & I also intend to start racing next year (looking into the DesmoDue series). So am going to sell the engine as it is, stripped down, with the spare crank cases.
    On close inspection I can see no wear internally and the internal oil screen had no metal filings in it.
    Am selling the rest of the parts on the bike which is now fully stripped down, all parts will we checked and cleaned before I sell them. I can provide photos of every part, or you’re more than welcome to pop around to have a look for yourself.
    I can’t resize the photos to upload them on here so if you send me your email address I can send you photos of whichever parts you are interested in.
    I also have a video of the bike running in all its glory which I can email you. The mileage on the engine is around 10k, it had 9.5k on it when I took it off the road and made it in a track day only bike, I've sold all the road going parts including the clocks. (Bike now has a Translogic dash fitted)
    See list below for all the parts which am willing to sell in whichever combination, I would like to sell thing’s hole like the front end together, both wheels. Etc,
    Full engine with injectors, Ecu, wiring, starter motor, exhaust. basically everything which would to need make a great engine upgrade for a 748 or 916 etc.
    PARTS SOLD
    Standard 998 powder coated in black.
    Showa fork re-valves & serviced new seals, bushes & oil at a cost of £248.45 Reaction suspension on 30/01/12 invoice to prove.
    Front brakes with race pads, fluid & new twin red braided hoses.( I think the 998 brakes different to and 748 & 9@#).
    F&R 5 spoke 998 Marchesini wheels powder coating in black, fitted with discs (Will sell discs with wheels or with brakes) Fitted with Michellin pilot slick 12/60/17 & Pirelli dragon supercorsa pro 190/55 zr 17.
    Rear thumb brake full set up including new red braided hose.
    MD production carbon fibre front mudguard.
    Translogic updated/new style race dash (Bought 23/01/12).
    Front race sub frame for standard clocks or race dash.
    Renthal 525 chain, front 14t sprocket & rear 36t sprocket with quick release carrier (not more than 500 miles old).
    Adjustable headstock tube.
    Clips ons with black levers.
    Top & bottom yokes.
    Steering damper.
    Front paddock stand.
    Standard 998cc (Stripped down as above) I fitting a power commander and had the engine set up on a dyno @ 118bhp with a good power curve, I have the print out. Regularly serviced with fully synthetic oil.
    PARTS STILL FOR SALE
    SUSPENSION
    Ohlins rear shock, Ride height adjuster £300 ono
    BRAKES
    Rear brake full set up with race pads with adjustable foot brake lever, i.e hose caliper, slave cylinder £100 ono
    BODYWORK/FAIRING
    Full set of fairings including Belly pan for race reg’s. I got the fairings painted and decal up about 6 months ago so there are some marks but generally in good condition.
    998 OEM front screen with rubber strip
    Single seat unit with new seat recover in Alcantara black
    Tank with stomp grips & gold keyless fuel cap, the tank has been repair at the rear with JB weld where it bolts to the frame as it was slightly leaking it may need doing again.
    All nuts, bolts Dzus clips & latches £300 ono
    UPGRADES
    STM EVR 48t 6 ramp Slipper clutch with all steel & friction plates set up to the right stack height, so you can just fit it straight to your engine. £350 ono
    Power commander (Bought 02/11/11) £170 ono
    Adjustable rear sets in black £120 ono
    Frame crash bungs £50 ono
    MISCELLANEOUS
    Rear paddock stands £50 ono
    Full exhaust system £100 ono
    Full cooling system including hoses £100 ono
    Wiring Free with engine
    Clutch slave cylinder £40 ono
    Rear sub frame with under tray £60 ono
    Swing arm complete £100 ono
    Battery £40 ono
    Various nuts, bolts & straps £10 ono
    Battery holder free with battery
    Etc Etc
    #1 labinx, Oct 16, 2012
  2. PM sent re-dash
  3. PM re clutch
  4. I broke my 916 on a track.
    In the gravel trap.
  5. PM sent re a few bits n bobs!
  6. All Pm answered,
    If you would like photo of parts please PM me your email address and I will you send them to you.
    Cheers
  7. Please see revised first post with parts which have been sold & prices for parts still for sell.
    Cheers
  8. what exhaust system and id size??
  9. Sorry exhaust sold
  10. Engine sold
  11. Pics of the clutch would be good please pla3108atyahoodotcodotuk
    Cheers
