For Sale Breaking 998s *full Bike* Carbon, Ohlins Etc ***updated Again***
Discussion in 'Parts, Accessories & Clothing For Sale' started by Tommy B, Aug 22, 2014.
  1. 998 Frame with V5 black powder coated (hpi clear on 03reg) with tax and mot + eccentric head tube perfect for 1098/1198 conversion (could do a deal with loom, coils etc?) - £1000
    Swing arm + hub + eccentric + rental quick release sprocket adapter and 520 renthal sprocket + all nuts (gold painted magnesium look) - £350
    Headlight bucket with ears (black powder coated) - £100
    Ducati 998R lower Yoke 56mm (Ohlins fitment) - £220
    Gold anodised top yoke + stainless fastenings (Magnesium look) - £60
    Ohlins FG8851 forks 996R/998R (10/01/2001) - £900
    Ohlins steering damper with harris bracket - £250
    Silver Valter moto rear sets with carbon heal guards - £120
    Mono subframe 748R - £235
    Brembo P4 front calipers Gold 4 pad type (998R) - £155
    Brembo Cast Iron fully floating disks (early type like found on foggy reps and sps) - £280
    Carbon Fibre Front mudguard (MS Production?) looks to be 848 type - £80
    Left hand switch gear - £35
    Right hand switch gear - £25
    Front Brake reservoir - £10
    Clutch Reservoir - £10
    Throttle assembly + cable - £25
    Headlight bucket to frame bracket - £10
    Front left indicator - £10
    Front right indicator - £10
    Rear Right indicator - £10
    Rear Left Indicator - £10
    Ducati Performance Carbon Radiator surround/V piece (998) - £80
    998 Radiators - £100
    998 rad fans - £25 each
    Standard Rad hoses 998 - £30
    996R engine, Sand Cast cases, Deep Sump, Corse vented clutch engine case, 3300k miles,) Just been dyno’d, running well at 137bhp 5/8/2014 – dyno man seemed to think its had some cam work…his dyno runs low so could be 140+ (no numbers F01 stamped!) Has been rebuilt at somepoint, “Ducati Manchester” race team roots…more info on request (will have fresh belts and filter when buyer is secured) -£1800
    Oil cooler and lines - £120
    Termignoli full 54mm system with Titanium cans (VERY VERY RARE) including rare heat shield - £1200
    996R ECU set up to run with the above (61600.630.00 – 996R-DUCATI007) - £200
    Standard 998 air box painted black with carbon wrap on sides - £85
    Airbox fastenings - £10
    Ducati Performance red star type radial clutch pressure plate + spings + bolts - £80
    Ducati performance chain guard - £60
    998 fairing lowers to suit belly pan (red with graphite painted vents) - £200
    998s side upper side fairings (black decals) - £210
    Left top fairing vent - £10
    Right top fairing vent - £10
    Side stand + bracket + spring etc - £65
    Lockset with 2 keys - £80
    996r/998 Injectors + Rail trumpets etc (998) - £150
    Throttle body fuel hose and connectors - £10
    998 Battery box with regulator bracket…slight repair - £40
    Brembo rear master cylinder - £30
    Rear Master Cylinder bracket + light switch (sticking) - £10
    Braded rear brake line - £5
    Rear brake reservoir - £5
    MS Production/LLmberger Carbon underseat heat shield - £100
    Rear disc- £35
    Rear disk bolts - £5
    Swing arm pivot axle - £20
    Brembo rear brake calliper - £35
    998 coils - £40
    Fuel pump - £80
    Rear brake light - £25
    Genuine Ducati Carbon Belly Pan 996/998R/S (road type) - £160
    Mono seat rear light bracket - £25
    748R mono seat, recently painted painted panels with gold fine lining RED - £300
    RED fuel Tank with black decals (recently painted) - £300
    RED genuine nose cone, white number board with gold fine lining, black decal (recently painted) - £200
    Crank breather tank - £20
    Dzus fastening kit - £50
    22 pin Front wiring loom - £50
    Starter motor solenoid - £20
    Horn - £5
    Standard Brembo later style front brake master and lever (bleed nipple snapped, good for spares) - £25
    Fuel tank pin and fastenings - £10
    Clutch push rod + bearing - £5
    Copper exhaust header nuts - £5
    Top engine bolts/mounts 998 x2 - £20
    Clutch and friction plates (worn but usable) - £15
    DID 520 chain, good condition - £45
    Air Temp sensor - £5
    998 later large bore Slave cylinder - £20
    Head race bearings - £5
    Bike is stipped, everything is cleaned and bagged where possible.
    All parts are 998 however most will fit any of the 748/916/996/998 series bikes...some parts will also fit later bikes...like mudguard, sprocket cover etc *PLEASE ASK IF UNSURE*
    I will combine items for and discount accoordingly.
    Everything must be sold down to every last nut and bolt!
    All prices exclude postage, i will however post as cheap as possible, please ask for a price.
    I will accept paypal as payment however buer must send as a gift or cover the transaction fee of 3.4%. A bank transfer is my prefered method of payment as is a whole lot easier for both parties and free.
    All parts are in good condition however please ask for a condition description and i will happily take photos of any marks.
    Photos on request
    Please either reply to this thread or start a conversation with me if interested in anything.
  2. Also have -
    Ohlins Rear shock DU9260 (748RS) for use with a short road arm simular as used on FO1 and FO2 race bikes just with slightly different valving (very trick) - £450
  3. Also have another set of Ohlins forks 748/916/996/998 fitment off an sps - £850
  4. Do I recall seeing a CF number plate hanger, or did that go?
  5. Sold that mate.
  6. Hi tommy would I need ohlins top or bottom yokes for these sps forks to fit to my 748s cheers
    #6 VtwinDave, Aug 30, 2014
  7. That's a long list, couldn't concentrate :Wideyed:
  8. Just the bottom yoke...you retain your original top.
    I could do a package with the lower yoke for £1050. If interested?
  9. I'll get back to ye about these
  10. Any damage on these forks and any pictures
  11. No damage, just a few rub marks from hoses etc.
    Ill pm you some pics later when im home.
    Tom
  12. What would i need to fit that DU9260 rear shock onto my (97) 748s
    Shorter ride height bar?
  13. Hi,
    Nothing at all, straight fit.
    Tom
  14. Great Thanks Tom, when you get a moment could you send a pic.
  15. I'll have the rear light.
  16. Tom if V Twin Dave does not want the forks and bottom yoke I will have them if they will fit my 998s in the same way, my calipers fit etc?.. see my avatar (mine are 4 pots) are these valved correctly (length etc) for a 998. I assume it's heavier than a 748.
    PM me the details and some photos after V Twin Dave has made his mind up. Thanks
  17. C
    cheers mate, but they're cheaper in eBay and have free post.! Thanks anyway.
  18. Please note the parts list at the top is from another bike..the bike I'm currently breaking has some trick bits otherwise standard.
    STM slipper
    Ohlins rear shock
    Ohlins damper
    50mm ti termi cans
    Oberon slave
    Mono rear subframe
    JHP corse type rear sets
    Etc etc
    Please message me for more details.
    #18 Tommy B, Apr 14, 2016
  19. Ok I see, the post for forks was 2014.
    #19 Not Carl Fogarty, Apr 14, 2016
  20. Can I have some pictures if the red 748 panels you have please
