For Sale Breaking 998s *full Bike* Carbon, Ohlins Etc ***updated***
Discussion in 'Parts, Accessories & Clothing For Sale' started by Tommy B, Aug 11, 2014.
  1. Updated List...loads already gone, whats left after after next weekend may go on ebay at an inflated price!
    Please see previous post for photos
    If theres anything you cant see on the list that your after please ask.
    Stripping my 2003 998 Bitsa
    Loads of nice rare bits for sale,
    Some prices may seem expensive, however i have had to base most of it on what things have sold for on ebay, then tried to make them a little cheaper.
    Bike is stipped, everything is cleaned and bagged where possible.
    All parts are 998 however most will fit any of the 748/916/996/998 series bikes...some parts will also fit later bikes...like mudguard, sprocket cover etc *PLEASE ASK IF UNSURE*
    I will combine items for and discount accoordingly.
    Everything must be sold down to every last nut and bolt!
    All prices exclude postage, i will however post as cheap as possible, please ask for a price.
    I will accept paypal as payment however buer must send as a gift or cover the transaction fee of 3.4%. A bank transfer is my prefered method of payment as is a whole lot easier for both parties and free.
    All parts are in good condition however please ask for a condition description and i will happily take photos of any marks.
    Photos on request
    Please either reply to this thread or start a conversation with me if interested in anything.
    Appologies for the rant, just want to make sure i can keep up with sales.
    Cheers Tom
    Ducati 998 Bits for sale
    998 Frame with V5 black powder coated (hpi clear on 03reg) with tax and mot + eccentric head tube perfect for 1098/1198 conversion (could do a deal with loom, coils etc?) - £1000
    Swing arm + hub + eccentric + rental quick release sprocket adapter and 520 renthal sprocket + all nuts (gold painted magnesium look) - £350
    Headlight bucket with ears (black powder coated) - £100
    Ducati 998R lower Yoke 56mm (Ohlins fitment) - £220
    Gold anodised top yoke + stainless fastenings (Magnesium look) - £60
    Ohlins FG8851 forks 996R/998R (10/01/2001) - £900
    Brembo P4 front calipers Gold 4 pad type (998R) - £155
    Brembo Cast Iron fully floating disks (early type like found on foggy reps and sps) - £280
    Carbon Fibre Front mudguard (MS Production?) looks to be 848 type - £80
    Left hand switch gear - £35
    Right hand switch gear - £25
    Front Brake reservoir - £10
    Clutch Reservoir - £10
    Throttle assembly + cable - £25
    Headlight bucket to frame bracket - £10
    Ducati Performance Carbon Air Tubes with inline filters (included) + indicator mounts - £200
    Ducati performance small Carbon Mirrors *RARE* - £175
    Front left indicator - £10
    Front right indicator - £10
    Rear Right indicator - £10
    Rear Left Indicator - £10
    Ducati Performance Carbon Radiator surround/V piece (998) - £80
    998 Radiators - £100
    998 rad fans - £25 each
    Standard Rad hoses 998 - £30
    996R engine, Sand Cast cases, Deep Sump, Corse vented clutch engine case, 3300k miles,) Just been dyno’d, running well at 137bhp 5/8/2014 – dyno man seemed to think its had some cam work…his dyno runs low so could be 140+ (no numbers F01 stamped!) Has been rebuilt at somepoint, has “Ducati Manchester” race team roots…more info on request (will have fresh belts and filter when buyer is secured) -£1800
    Oil cooler and lines - £120
    Termignoli full 54mm system with Titanium cans (VERY VERY RARE) including rare heat shield - £1200
    996R ECU set up to run with the above (61600.630.00 – 996R-DUCATI007) - £200
    Standard 998 air box painted black with carbon wrap on sides - £85
    Airbox fastenings - £10
    Ducati Performance red star type radial clutch pressure plate + spings + bolts - £80
    Ducati performance Titanium sprocket cover - £80
    Ducati performance chain guard - £60
    998 fairing lowers to suit belly pan (red with graphite painted vents) - £170
    Side stand + bracket + spring etc - £65 will fit most bikes
    Lockset with 2 keys - £80
    996r/998 Injectors + Rail trumpets etc (998) - £150
    Throttle body fuel hose and connectors - £10
    998 Battery box with regulator bracket…slight repair - £40
    Brembo rear master cylinder - £30
    Rear Master Cylinder bracket + light switch (sticking) - £10
    Rear brake reservoir - £5
    MS Production/LLmberger Carbon underseat heat shield - £100
    Rear disc- £35
    Swing arm pivot axle - £20
    Brembo rear brake calliper - £35
    998 coils - £40
    998 regulator/rectifier - £20
    Fuel pump - £80
    Rear brake light - £25
    5 spoke Alloy Marchesini Wheels (black powder coated) with Pirelli super corsas - £650
    Genuine Ducati Carbon Belly Pan 996/998R/S (road type) - £160
    Mono seat rear light bracket - £25
    748R mono seat, recently painted painted panels with gold fine lining RED - £300
    RED fuel Tank with black decals (recently painted) - £300
    RED genuine nose cone, white number board with gold fine lining, black decal (recently painted) - £200
    Crank breather tank - £20
    Dzus fastening kit - £50
    22 pin Front wiring loom - £50
    Fuel pump solenoid - £20
    Horn - £5
    Standard Brembo later style front brake master and lever (bleed nipple snapped, god for spairs) - £25
    Fuel tank pin and fastenings - £10
    Clutch push rod + bearing - £5
    Copper exhaust header nuts - £5
    Top engine bolts/mounts x2 - £20
    Clutch and friction plates (worn but usable) - £15
    DID 520 chain, good condition - £45
    Air Temp sensor - £5
    998 later large bore Slave cylinder - £20
    Head race bearings - £5
  2. Long shot I know but did all your part go already?
  3. Sorry yes all sold..however do have a lot of 916-998 parts..what are you after??
  4. I'm starting a 998 project, so am looking for all of it. What 998 stuff do you have?
  5. I may have a left passenger foot peg. Would need to check though.
  6. I'm building an SP so no good to me, sorry.
    Thanks for getting in touch though.
  7. I have a Leo Vince 57mm full system with to cans..used but still in the box
    Mono ally subframe
    Ohlins front end
    And loads of odds and sods..swingarms, hubs, looms etc etc
  8. Looking for a rear rim to suit 996/8 R . Do you have anything ???
  9. do you have any 998 radiators at all? cheers, John
  10. No 998 stuff I'm afraid.
  11. I'm looking for a crank case breather valve if you have one?
    Cheers
  12. Hi there - you mention about loads of odds n sods........... would you have the mounting plate / bracket for a 748/916 seat unit ? ( the bit that it pivots on when you lift it up )
    Cheers !
  13. Starting to brake another 998s if anyone needs any parts?
  14. Hi Tommy, Would you have a good 998 radiator at all ? Thanks, John
  15. Hi Tommy - do you have a seat release pin please ?(not sure what the correct description is ) as below -
  16. Hi Tommy. Is the CF belly pan in good nick? And how much?
    Cheers, ian
  17. Hi Ian,
    Belly will go with the rest of the sides I'm afraid..will struggle selling the rest without.
  18. Hi tommy, do you have one of those triangle coolant covers that go on the right side of the cylinders?
    I just need the one, stupidly broke one the other day.
    Thanks
    Rob
