For Sale Breaking Fully Running 1098s 2008 9700 Miles
Discussion in 'Parts, Accessories & Clothing For Sale' started by funkatronic, Oct 8, 2017.
  1. Breaking entire bike - many parts still available please ask if you dont see what you need
    All running & working very well- last belts service and oil change at louigi moto
    swing arm and tank have a scuff on the left side otherwise in very good & clean condition
    Still available
    Nice and clean Engine 9705 miles full service history
    will sell with manuals and maintenance stamp book
    Throttle bodies airbox and injecteors
    OEM Ohlins Rear Shock
    Maxton fully adjustable Race/track Shock
    Ohlins TTX Shock (very clean and tidy)
    Ohlins R&T Forks in VGC recently serviced
    Lightweight Forged Marchesini rear wheel large hub (front sold)
    Full Lockset with matching Dash - 2 keys and code card - Dash is in good shape (not cracked or misting)
    330m brembo brake discs/rotors in GC
    swingarm (dented) and
    eccentric hub VGC
    brake and clutch master cylinders reservoirs brackets and and lines
    clip on handle bars
    throttle assembly
    swicthgear left and right
    Yokes (ohlins fitments 53mm top 56 bottom)
    cooling system (rad & oil cooler coolant bottles)
    loom
    front and rear subframes
    battery box
    regulator (almost new)
    headlight
    lots of plastics inc OEM intakes
    Cordona PDQ8 pro race shift lever quick shifter with 3 ping plug top loom (848/1*98) and 2pin loom 748/916/996/998
    SOLD
    Frame with V5 (Cat C)
    Ohlins Steering damper
    Brembo M4 Monobloc Calipers
    Woodcraft Clucth Cover
    Adjustable Race Rearsets
    Lighweight Marchesinsi forged Front wheel
    70mm Termi full system with ECU
    OEM Seat unit and tail light and under tray
    Carbon Mudgaurd
    OEM Clutch Slave
    Seat Latch
    Carbon Termignoni Slip Ons (oval type) in VGC
    brake master switch
    side stand and switch
    #1 funkatronic, Oct 8, 2017
  2. Might be into the forks/maxton/frame/dash, send an SMS or email cheers :upyeah:
  3. I'm interested in the tail unit , steering damper and exhaust , how much are you looking for each part
    how much are you looking for the engine .
  4. Just out of curiosity, how much for the rest of the bike as pictured?
  5. Interested in the rear sets par dependant upon price of course!
  6. Don't know where the 'par' came from!!
  7. PM sent
  8. Same question?
  9. Thanks for your interest,
    will reply to your messages and PMs individually shortly
    i might be prepared to sell the bike as is if you are quick and keen (buyer are already queuing up for the bits), but please dont think that means I'm going to entertain silly offers just cos it has no fairing and a few scuffs!
    will send you PMs if you would like to discuss further
    FYI as of today the bike is almost as pictured with
    It has the Maxton GP7 shock in
    70mm termi full system & ECU (with a header than needs repair)
    Nearly new Set of Dunlop KR106/108 slick tyres
    IT DOESNT HAVE
    slipper clutch (although i have the OEM)
    clutch cover (have OEM)
    GB racing engine covers
    The air intake and shroud are part of the track fairings so wouldnt be included
    standard levers not ASV brake as pictured
    R&G Fork protecteors
    I think i might have used the brake pads for my other track bike :)
  10. Morning pal, I'm interested in the M4 Brembo's. I will inbox you now.
    Stu
  11. Hi,
    Do you have the original side stand available and if so, could you post a picture with a price please?
    Thanks,
    Bob.
  12. yes pretty sure i do will go find it and take pics, please PM me your email thanks
  13. Hi,
    Did you get my email address ok?
    thanks,
    Bob.
  14. hi yep, I'm still looking for it :)
  15. Sorry, I wasn't chasing you, it was my first PM and I wasn't sure if I had used the correct process of starting a "New Coversation".
  16. Hi, I am interested in your full Lockset with matching Dash - 2 keys and code card can you give me a price?
  17. sent you a pm
  18. Are the master cylinders for sale?
  19. Yep will pm pm you
  20. Is the standard rear brake lever available?
