Can anyone tell me where I can get hold of the actuation pin and barrel for brembo clutch levers? specifically the brass parts that push into the clutch at the bar? Need one for a 2004 st3 and also for a 2001 748?
I don't think you can buy them seperately? You will need to either rob them from your existing lever (use a socket to push the brass bushing out and split the lever) or buy cheap replacement levers and use them. For all other brake parts I've used Moto-Racing in the past. I know some people have had problems with them but they've always been fine for me... Brembo Spares / Accessories - Performance Motorcycle Parts -
Bugger.! Replacement levers for both bikes dont have the brass parts and the ones on the original levers had literally welded themselves into themselves which has meant they have come out but a bit worse for wear Will have a look for some cheap cheap levers with the brass parts too Thanks Ant
You should be able to get pattern replacement levers for about £15 each delivered, or maybe hunt ebay for cheap originals.
Have just looked on the bay but they dont seem to have that bit Duc Leeds confirm oem is the whole thing at £200 odd Will post up a wanted - hopefully someone has an old knackered lever or two kicking about!
Are they the gold Brembo mastercylinders? These were used on quite a few bikes, including Aprilias, so it may be worth widening the ebay search!
