Can anyone confirm the disc on touring S DVT 2016 are 330mm ? I'm looking at upgrading to serie oro but being told that 320mm are the correct 1s
330mm which you can easily confirm by the 2 x 5mm spacers between the caliper and the forks. You can use 320mm discs if you omit the 5mm spacers. I actually prefer 320mm HPK discs to 330mm discs. Andy
Thank you. and yes mine has the spacers but now tempted to go for the 320mm as read doesnt make any difference and would be alot easier to remove callipers
320mm on my '16 Enduro ... didn't realise it was 330 on the 'S' thought I'd got the wrong ones for a while. ORO's seem good so far, not out many miles on 'em yet.
I have 320mm on my 1260 for the Oro discs, the 5mm spacer is simply above the calliper than between it and the forks. Love them!
I opted for the 330mm version in the end. slightly more expensive but thought thats the OEM size so stuck with it
