I purchased both of these with the intention of fitting them to my Hypermotard 796 which uses regular axial master cylinders, however I haven't fitted them as I'd also need to buy a new set of brake lines too (the stock lines don't have banjo connecters but rather just screw directly into the master cylinders) which I can't be bothered with. The brake master cylinder is off of a 848, I believe the brembo model is: PR 18, although the markings can be seen in the pics below. An adjustable lever is fitted to this and the brake light switch is still in place. Unfortunately there is no fluid reservoir however the reservoir mounting bracket will be included. The clutch master cylinder is off of a 1199, I'm not too sure on the model number but it is marked with: +15 2F02 and 19 (The piston diameter?). This comes with the fluid reservoir + bracket but doesn't come with a lever or switch. I'm looking for £85 each or £160 for the pair. Brake master cylinder Clutch master cylinder
The brake master cylinder has been sold on ebay for £102.50. The clutch master cylinder is still available for purchase.
