For Sale Brembo Rcs 15 M/cyl
Discussion in 'Parts, Accessories & Clothing For Sale' started by nelly, Jun 18, 2021.
  1. Brembo RCS 15mm master cylinder. Brand new, with fittings and brake switch. It's been trial fitted but then removed in lieu of a 19mm. Adjustable ratios 18/20 and with fold up lever.
    Being 15mm is only really suited to a single disc setup, Scrambler would be ideal, but it's a fraction bigger than the early 14mm twin setups used on earlier bikes but I can't confirm it'll be much of an upgrade. It would also work on something like a motard bike.
    £200 delivered.
  2. Neil, am I correct in thinking this m/c doesn’t have the blind threaded hole to mount a reservoir bracket ? Andy
  3. Yes Andy. Brembo do a kit that mounts off the clamp bolt though. Very tidy and comes with everything you need. The RCS does come with a brake light switch which negates using a pressure switch like the earlier radials though.
  4. That's the one Andy. Works a treat
  5. Don’t suppose you have one in your stock ? I’ve noticed most of the parts stockists are showing out of stock. Andy
  6. No Andy. I get my Brembo parts from Bike Torque Racing. They had stock last week...
  7. I’ve got the 15RCS on my RRV, absolutely awesome on single disc set up. Works phenomenal with the M50 caliper.
  8. @nelly, if the m/c is still available Neil, I’d like it please. PM how you want paying and I’ll do the necessary. Cheers, Andy
  9. Pm sent Andy.
  10. Thread closed:)
