Brembo T-drives - Worth The Money?
Discussion in 'Clothing, Gadgets & Equipment' started by BobDavo, May 4, 2023.
  1. On my track bike I have Brembo Corsa Corta 18 x20 M/C, HEL lines and Z04 pads.
    I have heard nothing but good things about the T-drives - does anyone have experience with them?
  2. Taken from a stockists web site.
    BREMBO T-DRIVE DISCS
    "T-DRIVE" Disc is a new-generation product that feeds back the output obtained by MotoGP and SBK.
    A special guillotine type Surface developed between the disc and the bell, which studied the tolerance of machining (Patent pending) By Mount.
    In addition to enabling radial and axial Floating, it also reduces the total weight of the disc to Large width than the conventional type using a circular Bush, especially when it is subjected to thermal ? Improve resistance to mechanical stress and more efficiently transmit torque during braking.
    Also, 5. We also succeeded in narrowing the sliding surface while keeping the disc thickness of 5 mm and reduced the weight.
    As a result, the weight and inertia are kept to the minimum Small limit, making Handling much more comfortable than before, and dramatically improved the running performance.
    Not cheap, probably a 25% premium looking at the £600 to £700 price tag on the Brembos. If you are looking to shave 1/10 s and you have the skill and finances, would definitely seem to be a positive upgrade. Andy
    #2 Android853sp, May 4, 2023
  3. HPK’s are a good disc :upyeah:
    depends if you need more braking power really.
