Broken/no Key Ignition Barrel And Water Hose 996
Discussion in 'Wanted' started by Messer, Jan 30, 2020.
  1. Hi
    I need the plastic cover in nice condition from a 996/916 ignition barrel please and also the lower hose from the bottom of the water pump.
    does anyone have anything?
    thanks
    Tony
  2. Il have a look in my box of goodies tomorrow matey
  3. Thanks boss!
    apreciated!
  4. Would the hose be the same as on a 748 998 if so I should have one
  5. I would have thought so yes !
  7. Sorry mate not got any :(
  8. I was thinking that or the one beside it
  9. Actually, you might be right as the one beside it appears a larger bore which would make more sense being attached he’d directly to the pump. It’s hard to tell from the pictures, I’d have to look at the parts diagram & get the part no.
  10. I’ll dig it out tomorrow but it’s this one!
  11. Part no 800.1.037.1A
    part 32 in the diag
  12. No not that one
    This one
  13. I have these if you want one let me know.
    All off my 748.
    Steve
  14. I should have put my glasses on:(
    Part 23 in the diagram, Ill get the p no when I get hone
  15. 800.1.136.1A is part 23 in the diag
  16. Thanks for the replies, there is a possibility my friend might have one from his 998. so will check that out firstly. Unfortunately this pipe is missed off all the microfiches by the looks of it, you can make it out in the background of the diagrams, but the pipe appears to be a ghost!
    I think part 23 is referring to the one just in front/above it..
    Still need the plast cap from around an ignition barrell if poss? Mine had something stuck on it from an old alarm and the glue has taken some of the writing with it.
  17. I would get a new hose, rather than relying on some unknown part. Especially in the application that it is used.
    Can only be a few quid for piece of mind.
  18. I would, but I cant find it on the microfiche on all of the models I have look at so struggle to give a part number to a dealer. I normally just get all of my new parts online..
    I will give them a call
  19. Found it! its on the cylinder schematic so I can get a new one! thanks all, I just presumed it was NLA new given it was ghosted out
