Campervan Prices
Discussion in 'Lounge' started by broke, May 31, 2018.
  1. I'm thinking of buying a 21yrs old Citroen 2ltr diesel camper van, with 41k miles on the clock it's a Royale model if that's any help with a bunk over cab.
    Anybody have any idea roughly what it's worth, mot runs out on the 14th June, and what should I look out for.
    Cheers,
    Broke.
  2. No idea about that one, but if it’s any help there’s a guy on UKGSERs selling a Merc Autotrail Motorhome, £30k and 30,000 miles
    :upyeah:
  3. 21 one year old Citroen? Good luck, I would go for a 21 year old Mercedes if you can!
  4. France is full of old pugs and Citroen’s ;)
  5. I know, the French don’t like to buy foreign lol
  6. mrk 1 ducato essentially. parts still readily available, a v,good van. gearbox syncro issue but not an overly expensive fix. corrosion not the worst with these van but bear in mind any welding to the floor can involve a major strip out due to gas and electrics, depending on condition and servicing of gas and electrics, somewhere between 5k and 12k
  7. Yeah!...........but I live in sunny Wales :worried:
  8. i still see plenty running around in good condition. and much older.
  9. Sounds high to me, but then I think the world has gone mad for bikes a d campers and their prices.
    Chances are tho, you can buy, run two seasons then sell for similar money.
  10. being exe fiat tech and living in the land of the camper van, seems v,fair to me. but, i aint seen it
  11. #13 noobie, May 31, 2018
  12. Thanks noobie, just checked.
    It says passed on the 15th May, but with rust on brake ferrules, and immediately below that it says failed on the 15th May with rust on brake ferrules ?
  13. 2000 PA? . Seems curiously low?
  14. in the garage most of the time being fixed;)
  15. Do these run the peugeot 1.9 diesel?If so they run forever.
  16. most camper vans are low millage.
    not all are compatible with fitting tow bars just in case you are thinking of taking a bike with you.
  17. Is it a good idea buying a diesel at the moment? In a couple of years you will have to give it away.... although they might have a scrappage scheme and you could do OK out of it
    Decisions... decisions !
