899 Can I Adjust Front Brake Position?
Discussion in 'Panigale' started by Gweev, Apr 3, 2016.
  1. I want to rotate the front brake lever downwards a bit too take some weight off my wrists but when I loosened the bolts off the thing didn't move.
    Is there something preventing the lever rotating I'm not aware of?
  2. There's a pin into the handlebars that locates inside the clamp sections of the brake handle that stops it moving.
    I fitted ASV levers and wanted to rotate the clutch so found you can actually pull the pin out carefully with a pair of pliers and position it as you wish!
  3. Ah OK cheers.
    Are there a series of pin holes in the handlebar or just the one?
  4. Only one hole, for the clutch anyway. I had to pull it really hard so doubt you'd be able to put it back in at a later date to be honest but as long as you're happy with that then no harm done.
    This is the first bike I've ever had that used this setup, normally there's nothing so I'm not worried about the handle rotating on the bar or anything. [emoji4]
  5. Ok thanks.
    At least I miss know I have to take the champ completely off to rotate it.
