Hi guys The part numbered as number 15 on the attached main stand diagram for a 1200 MultiStrada is described on the parts fiche as a pin. (Its a damned expensive pin too) It looks more like maybe a bleed nipple though? What actually is it and is it an essential part pls ? Thanks for any help
Awesome thanks guys - that makes perfect sense. There is nothing there at the mo, so working just from a fiche was a little confusing It works out around £18.00 with postage. A lot of corn for a little part
It’s definitely the side stand pin. As previously mentioned, a bolt with a lock nut will suffice. I used a ti nut and bolt so as not to have galvanic corrosion (think that’s the term!) in that area.
The pin is for the centre stand spring. If yours is a sport and didn’t come with the stand, it won’t be there. If you need one to fit the stand, they’re about 12 quid from your dealer.
