Anyone had any carbon from these guys? Any feedback would be great as I need to get a heat shield for my pipes 131mm hole centres. Cheers
Nope but see if these guys have what you require; very good quality. http://www.ilmberger-carbon.de/Start.aspx
Yes I used them quite a lot Tony is very knowledgeable, but he does buy a lot of stuff in i belive and you can wait quite a long time but it's good stuff and reasonable cost.
I've used Carbonmoto a few times Might be worth checking these guys too http://www.worldofqbcarbon.com/store/
Meh! I had some bits a year or so ago which were all good but had some more parts sent over earlier this year which were sub standard; swing arm cover which I actually had to cut a piece of it off because it rubbed against the chain and a front sprocket cover which I had to reform because it rubbed against the drive shaft! I guess that means that parts are bought in from various sources and there is no cohesive quality control.
Conquest stuff looks nice. I just need a heat shield at the minute due to swapping my pipes as the std one doesn't fit!
Just bought and fitted one a fortnight ago. 131 centres. Very impressed with it, good quality ,bargain at £30 .
Bought a few cf parts from Tony at Carbon Moto in the past. Very good quality and the fit is spot on. Parts have been on the bike around three years now and haven't had any cracks or blemishes yet. Thumbs up from me
CarbonMoto or CarbonFibreforDucati are total shit, don't waste your money like I did, total waste of time as is the guy mentioned above that runs the place
Just got a 748s I notice there are a few different version of exhaust Heat shields, I presume they all fit but the design of it is based on your preference or is it determined by what link pipes you have ? CarbonKing any good, they appear to be the same as Carbonmoto but 10% more $$? I want a Twill weave, gloss with UV resistance, would ideally like a common supplier to ensure consistency of the weave Looking at conquestcarbon.com at the moment based on sugestions, limited pieces for a 748, no v chin guard, side arm piece Where do you guys get the slimline carbon tank pad?
