Just wondering if fitting a complete set of disk bobbins to these iron floaters will it remove a little play (tighten them up a bit)?? If not I wont bother as there not that bad, Maybe the carriers that wear?
They will have a tolerance I would think? Or is it rotational wear you mean? If so it's more likely the alloy carrier that has gone a lil oval? * if they are alloy...
Yep a little rotational wear, Its not a problem, Probably just me been fussy but would change if it would tighten things up a little
They usually wear on one side where the brake force is, as they are non directional try swapping the discs over perhaps...
