I am toying with the idea of making my own exhaust for my 1st gen 1100s, (I used to make custom stainless exhaust for cars) but I will have to remove the cat and the exhaust flap thing. Is it ok to? I think the O2 sensor is pre cat so shouldn't put EML on(I might b wrong) but I don't know what the exhaust flap does, maybe helps with engine braking??
The flap is to restrict noise levels to pass regs, I've binned mine and it's made the bike smoother trough the mid rev range
Well I tried to remove the flapper valve flap but the screws must be glued in they wouldn't budge ! Just removed the cable end from the valve works a treat and very easy to do.
Sorry your right they are cross headed screws that have been spot welded in, I tried to chisel the weld off but ended up drilling em out
