V4 Chain And Clutch Adjustment V4 Multistrada ?
Discussion in 'Multistrada' started by mikeybikey, Sep 28, 2022.
  1. I am a bit confused ( does not take much ) about the chain adjustment. Once the bike is on the side stand and the gauge fitted to the swinging arm, do you press down on the chain above the gauge so that the link stud align with the gauge for correct setting, or do you press the chain up and down with on finger and then release and then line up the studs with the adjuster ?
    The manual seems to say both ?
    Also is there simple way to bleed the clutch fluid ? There is what seems to be a bleed nipple on the handlebar next to the reservoir ?
  2. I just bleed the clutch with the one on the slave cylinder, not sure why there's one up top too, I'm sure someone will tell us.
  3. Yes, I agree, the manual contradicts itself, I settled for the finger pushing down and holding while checking the measurements
    But that's just my guess
  4. Chain tension check is push the chain down firmly, release and measure.
    Most issues with the clutch come from air in the master cylinder. Air rises up the system. Bleeding at the master solves 99% of any issues.
  5. Re the Chain, the Ducati supplied guide setting is for the bike on its side stand and switched off. I set mine up in this way and then re-check on the centre stand (if you have one), mark the guide with the centre stand setting and then use that to check and adjust when on the centre stand - so much easier that way. Agreed that it needs a firm push down and then release and do that at different points in the chain to find any tight spots.
  6. The clutch fluid has gone cloudy after 4000 miles. I have now done 7000 miles and the clutch is working perfectly; but i'm going to change it. As I want to replace all the fluid I intend to bleed the fluid from the slave cylinder as bleeding from the master cylinder would only replace the fluid in the reservoir. Have I got this right ?
  7. Clutch fluid routinely discolours in a relatively short period of time. It doesn’t seem to affect the performance of the fluid at all. You are correct in your assumption, bleeding from the slave cylinder will flush the old fluid out. Andy
  8. Thanks Andy. I will leave it alone and get the dealer to change it at the 9000 mile service
  9. My old MS1260s also had to be set to “Urban mode”.
    is this the same for MSV4s?
