1199 Chain Length
Discussion in 'Panigale' started by Regenwulf, May 2, 2018.
  1. Quick question (I have searched previous threads but my tiny mind became confused...) re final drive gearing on a standard 1199...
    It sounds like up'ing the rear sprocket to 41 (39 is standard, right?) is a good idea, and consistent with what they did on the R. I assume this keeps a standard 15 tooth front. Based on that, what length of chain would be needed? I think that 104 links is usual but with the bigger rear cog presumably a few extra links would be needed - any clues on what length is best?
    Standard chain is 530 pitch I believe, so slightly smaller and lighter at 525 would seem reasonable for low mileage track use - agreed?
    This would be mainly for track use.
    Cheers all.
    RW
  2. Hello there,
    Last year I done the same. I think std chain is 525 pitch. Not sure on length as got dealer to change. I went with a DID chain and R 41T rear sprocket. Std 15T front. Used std Ducati sprocket so I did not need to change sprocket carrier. I think most people on track use a 520 pitch chain.
  3. Gearingcommander.com
  4. I am running 15/41 with a 106 link 525 chain. As PCRR stated 525 is standard and some go down to 520 setups.
  5. Great, thanks fellas. 520 pitch chain with 15/41 gearing and 106 links it is!
  6. Just done mine, 520 106 link RK Gold chain with 15/41 Renthal gearing. Well pleased with it
