Chain Rubbing Swing Arm And Edge Of Tyre
Discussion in 'Newbies Hangout' started by steve james, May 5, 2023.
  1. Hi all, just bought a 1299 Panigale S 2015 and after just doing 300 miles I can see that the chain is rubbing the swing arm and the edge of the tyre. I have found some posts on here discussing the swing arm rub but nothing with anybody having tyre and chain rub. Has anyone had these issues and got it sorted? Bike has done 10,000 miles
    Thanks
    Steve
  2. How worn is the chain guide? The one on my 1299 needed replacing when the chain started to rub the swing-arm. After replacement all was fine.
  3. I will take a closer look, possibly look at changing guide and chain and sprockets and see how I go then......Thanks
  4. Welcome to the forum Steve.:)
  5. Does it have standard tyre size?
  6. Thanks, have a feeling I could be spending quite a bit of time on here
  7. Yes all standard
  8. Welcome and enjoy
  9. Has the concentric hub been rotated the correct way? Is the chain/sprocket standard length/teeth?
  10. Did that ( rotate the wrong way) on my 916, couldn't work out for ages why the tyre rubbed on the hugger, before forums and being able to ask for help
  11. chain and sprockets are all standard, don’t know which way hub has been rotated as chain all adjusted prior to me buying bike. How would direction of rotation affect bike ?
    Thanks
  12. On the 916 , if you rotated the eccentric hub the wrong way, it raised the wheel, wrt the swing arm, and the wheel would then rub the hugger ( attached to swing arm), rubbing solved by then rotating the hub 180 Deg.
    #12 Ivor, May 6, 2023
  13. Thanks, will ensure rotated correct way when I change chain and sprockets
  14. Ah yes, the old days where we learnt from our own screw ups rather than other people's.
  15. Like most of us :D
    Welcome into our mad house
