Diavel Chain Slap
Discussion in 'Diavel & XDiavel' started by Rick B, Jun 2, 2017.
  1. I know its a standard problem with the early Diavels chain slapping the swing arm even tho the chain is at the right tension, I've heard that putting some rubber on the swing arm numbs it, but has anyone got any pics as to where it should be placed?
    Thanks
    Rick
  2. I have no pictures, but you stick the rubber pad under the lower run of the swing arm protector, place it where you can see the wear marks from the chain, it only needs to be a thin piece of rubber, a couple of mm's thick will do the job
