Might seem like a odd question but, if I wanted to change the suspension on a standard 2014 Triumph ST ABS to that of the 2014 STR ABS is it as simple as just changing the Forks and rear shock? Or are there electronics to consider or anything else which makes the whole idea cost prohibitive? Thanks for any pointers.
You might want to ask that specific question on a Truimph Forum, If they have only changed or upgraded the suspension and the geometry is the same for both models then yes, no idea if they have any electronics in them though?
I'm not sure if the yokes are different on the front but would be surprised if they were, the rear shock is a straight swap. There are no electronics to worry about. Does the new ST run radial brakes? The STR definitely does...
