Change to kmh??
Discussion in 'Multistrada' started by Jase1, May 13, 2012.
  1. I know this was answered previously on ducatisti but can't seem to find on here. Just need to know how for when I hop
    Off ferry. Cheers all
  2. Got it filed away on home PC ....will see if anyone replies otherwise will post up. When you going?
  3. Here you go :
    Digital Dash Speed Display / Speedometer - How to convert kmh to mph
    With ignition off, hold in the headlight flasher and the indicator cancel switch together then turn on the ignition. The main display will show 'units' and you can then use the indicator cancel to select which ones you want, save (keep the indicator cancel button depressed) and exit.
  4. Switch ignition on whilst holding in the headlight flasher switch and the memory switch on the L/H bar. It will offer you the option then, just select and confirm.
  5. Bugger, 1 minute too slow LOL.
  6. Cheers guys
  7. Thanks I also needed to know this
