1200 DVT Changing Sprockets 42 Tooth On Rear
Discussion in 'Multistrada' started by Mobile Chicane, Sep 4, 2019.
  1. I've just had a look at the B+C website and then called them and it seems that they cant get a 42 tooth rear sprocket for my 65 plate 2015 1200 dvt multi.
    I believe I'm running a 530 chain (will have to check once I get home) and apparently the biggest they do is 41 tooth for the rear.
    If anyone has fitted a 42 tooth on the rear with a 530 chain where did you source it from ?
  2. EBay. No bother
  3. Bike torque racing, check their website
  4. just rang them they only do a 40 tooth
  5. Its funny that one of the most common mods is also one of the hardest to source!
  6. That's why I went to a 525 chain, because there is more choice for sprocket sizes.:upyeah:
  7. TBF if you change to a 42T IME you want a chain change anyway, 2 links longer, so may as well do the front while you're there and change the lot
  8. irritatingly I have only just replaced the chain
  9. It's all here
    https://www.ducatiforum.co.uk/threads/multistrada-gearing-changes.66852/#post-1378170
