Core blimey I feel bad asking this as I thought I would have enough gumption to be able to follow simple instructions. Any road up I'v just taken delivery of a 2014 Multi 1200 (not S) and I'm settling in to it. No problems changing the clock but when one cons reading is in l/100km and the other cons reading is in km/l I thought I should change them to mpg. So the book tells me to hold down contemporaneously (which I take to mean at the same time) the flash button and the reset button to get to units settings, but when I do nothing seems to happen. I've tried from different start points on the screen but I can't make any progress. Can anyone see where I'm going wrong. All help appreciated. Thanks in advance. TB
You just beat me to it Android! I too struggled with this for a while but got there in the end. The manual isn't very clear.....
Gentlemen, I really appreciate your help and assistance with this as I wasn't getting anywhere. As you know already your instructions work, so I'm all set to go, big thanks to you both. PS, you probably also know this, but after a short ride this morning I found out that this bike really comes alive over 5 grand. I'm happy. Thanks again TB
If you rev to 4000 + rpm before you change into 3rd, it’ll run smoother. Aim to do not less than 40mph in 3rd. Andy
