1st job painted a lacquered Brembo logo. 2nd job raided savings of £1600 and put Termngoni exhaust on
What was the first then? Surely the cheapest mod 0n any multi is the 50p spring to remove the flapper valve
I would get some protection on the clutch cover, Rhino tape or 3M if you look close you will see wear marks already!!
@manxxl if you'd of listed/explained what you actually did, I think more people would of joined in on this thread. I suspect the first item at £5 were replace the brake bolts with stainless ones. Well, I was wrong about the first item.
I’m particularly impressed with my crash bungs, not only were they free, but they’re a great conversation piece. They are ‘Edge’ skateboard wheels, some 8mm threaded bar, some plastic spacers and 4 dome-headed nuts.
