Cleaning Up Original Silencers (st4s)
Discussion in 'Detailing and cleaning' started by indiecourier, Feb 26, 2016.
  1. I've just bought a low mileage ST4s which, apart from the paint on the crankcases (mostly hidden by fairing, anyway) is virtually immaculate.
    The one thing which catches the critical eye is the chain-side silencer .... in certain lights you can see a sort of staining, like a dribble running from upper to lower.
    I've tried brake cleaner and a light bit of polishing with Peakes Metal Polish .... nice and clean but still with underlying staining.
    Any suggestions?
    I know I'll probably be putting it through a hedge before long but while it's tucked up in the garage I'd like it to be as tidy as possible.
  2. Yoshimura stain magic - not cheap but absolutely s**t hot
  3. 2nd vote for yoshimura stain magic
  4. Duraglit from Tesco (half the price of Ebay) cheap as chips and twice as effective (as chips) will beat anything with a Japanese tuner on the tin and won't smell of fish ;)
  5. best results I've had been using fine / ultrafine scothcbrite with plenty of water, use with the grain to obtain original brushed finish. You may end up doing the whole silencer (left & right sides?) sleeve for continuity and it's fairly labour intensive.
  6. So completely refinishing both silencers then?
  7. yes, but only as I wanted them both the same, if you're not bothered then just address the stain, may look a little bright at first but in time it'll dull down.
