Closed Clutch Cover Wanted...
Discussion in 'Multistrada' started by Steve Joyce, Dec 12, 2012.
  1. ...for my '05 MTS. I've got an open one but the noise is irritating!! I've found one on ebay second hand £32.50 plus £14.99 P&P. Seems a bit steep! Am i just being tight? Will I need a gasket to go with it or do they not have one as its a dry clutch?
  2. Yes there is a thick rubber gasket with brass inserts.
    Yes you have to pick and choose which you bid on ....I think that other model covers would fit, so maybe try to expand your search
  3. It won't make a lot of difference.
    You probably need a new clutch basket but that will only make a difference for a short time.
    I think people get better results from adding another clutch plate but i have never tried it myself. I like the noise and the worried looks on non-Ducati riders faces.
    Quiet clutch modification for Dry Clutch Ducati - Ducati Superbikes
  4. Pretty sure I have a decent one and gasket if you're interested?
  5. I might try and listen to another one, I'm no Ducati expert but it does sound louder than I remember them to be. If it is louder then I'll get someone to see if it does need a new basket.
  6. Awesome....I'll get the noise checked out and if everything is ok with the basket etc then I'll contact you about buying it off you.
  7. not being tight but that price is way over the top, postage is also over double what a courier (try interparcel website) would cost
    there are a load of decent covers out there for a lot less money
  8. Sorted...:upyeah:
