Hi all Need some advice re:1199 clutch. On track beginning of the week and lost drive like clutch slipping cut day short and pulled clutch. Plates are blue and smelt of burning. Installed new full set Barnett clutch plates today after soaking in oil, re-bled clutch and the same thing has happened no drive like clutch slipping when the bike gets warm. Pulled the clutch out and the plates are almost dry. Oil level was good using correct grade and no tell tale bits in the dropped oil or on sump plug magnet. Recently had valves checked by nelly too. Any ideas greatly welcomed.
