996 Clutch Fluid
Discussion in '748 / 916 / 996 / 998' started by Mattyc, Dec 10, 2021.
  1. Recommend me a clutch fluid.
    Looking for whatever is oem/performs the best.
    Ta
  2. Any major brand DOT4 should do I reckon.
  3. My dad used to work for BASF. Apart from the tapes you might know them from they are one of the largest chemical companies on the planet. The plant he worked in made brake fluid. Depending on the customer they filled drums labeled BASF, Castrol, ATE etc. The only difference was the dye some of them had put in. Any DOT 4 fluid is good.
  4. Any DOT4 it’s not heat sensitive like brakes may be
  5. Use whatever you put in the brake circuits. I've been using Brembo DOT 5.1 recently, simply because I bought some being sold cheap (I know that you can't use DOT 5 which is silicone based). I don't ride in a way that would mean that the higher boiling point of 5.1 would be noticeable!
    #5 Recidivist, Dec 10, 2021
  6. Motul RBF660 it is then.
    Thanks for the replies.
