Clutch Stack Height
Discussion in 'Supersport (1974-2007)' started by jayw996, Aug 12, 2023.
  1. Hi,
    Anyone know the clutch stack height for a 95 900ss? I can't find the info anywhere.
    Thanks!
  2. Memory says it’s 38mm but that needs checking as it’s at least a couple of years since I did my last one.
  3. Thanks, will take a look
  4. IIRC, the spec is 38.5mm but you'll be better off with a little less - no more than 38 otherwise you'll struggle to find neutral at standstill.
    I set mine to around 37.5 and have no problems finding neutral and no slippage.
  5. That is great, Thank you!
