Pleased to announce we have taken on the UK agency for CNC Racing, sponsors of Althea Ducati in WSB......Open clutch covers, pressure plates, Termi dB killers for the 749/999, rearsets, slave cylinders, reservoir caps...you name it...I tend to keep open covers, pressure plates and timing cover plates in stock.....anything else takes 3 days....... Ducati Clutch Slave Cylinder £111 Black, Red, Gold, or Silver Open Clutch covers £120 Black, Red, Gold, or Silver SS/Monster 2 valve Belt Covers, Alloy and Perspex , Black or Silver £324 Belt Covers...Hypermotard, Sport Classic, S2R 1000, Monster 1000 and 1100, Multistrada 1000 and 1100, £357 Timing Inspection Covers, £27 Black, Red, Gold, or Silver Clutch Drum £162 Sprocket Cover Black, Red, Gold, or Silver, £54 Rear Wheel axle nuts Alloy £42 Titanium £213.60 For 1098/1198/Streetfighter/Multistrada 1200 Alloy £60 Titanium £213.60 Front wheel axle nuts Alloy £21 Titanium £66 Termi dB killers 749/999 £66 5 bolt Alloy Sprocket Carrier £129 Black, Red, Gold, or Silver 6 bolt Alloy Sprocket Carrier £129 Black, Red, Gold, or Silver 4 spring slipper clutch ( no plates ) £924 Pressure plates in Black, Red, Gold, or Silver 6 spring slipper clutch ( no plates ) £924 Pressure plates in Black, Red, Gold, or Silver Steering head yoke nut, multi hole, Black, Red, Gold, or Silver, £46.20 Steering head yoke nut, multi hole, Hypermotard only Black, Red, Gold, or Silver, £46.20 Clutch springs, Black, Red, Gold, or Silver, £34.50 Fully Adjustable CNC Rearsets, Monster 696, 796, 1100 £357 Black, Red, Gold, or Silver Fully adjustable CNC Rearsets, Streetfighter, Black, Red, Gold, or Silver £297 Fully adjustable CNC Rearsets, MV Agusta, 750/1000 all models £240 CNC Rear Caliper Bracket Monster S2R 800, S2R 1000, S4RS £138 CNC Machined Yokes, inc steering stem M620, M800, M1000,S2R 800 and 1000, S4, S4R, S4RS £672, Black or Silver Bar Risers, Monster 620/800/1000, S2R 800/1000, S4, S4R, S4RS £60 Black or Silver CNC Machined Yokes M696, 796, 1100 Black or Silver £672 inc steering stem CNC Machined Yokes Hypermotard £672 inc steering stem, bar mounts and stem nut cover Set of 4 billet Alloy frame plugs £48 , Black, Red, Gold, or Silver Anodised CNC Bar Ends Gold, Silver, Black, Blue, Red £39 Swingarm Bobbins, M6x35 or M8x35 Gold, Silver, Black, Blue, Red £18 Hypermotard Bar Risers, Black or Silver, £186 Hypermotard Bar Riser for use with Ohlins Rotary Steering Damper £288 Bar Riser spacer Black, Red, Gold, Silver £24/pr Fork Preload Adjuster in 17/19/22mm for Ducati, Triumph, Aprilia, Honda, Suzuki, Yamaha, Kawasaki, BMW £42 Available in Black, Red, Gold, Silver and Blue Ducati Clutch Collets available in Black, Red, Gold, Silver and Blue £21 Ducati Clutch pressure plates, various designs £72 Oil filler caps, in Black, Red, Gold, Silver and Blue, for Kawasaki, Honda, Suzuki, Yamaha, Bimota, Ducati, Triumph £18 Allen Bolt type fuel filler caps, in Black, Red, Gold, Silver and Blue, for all above ( except Honda CBR1100XX, X-11 or VFR range £18 CNC Alloy QR Fuel Caps All circular Ducati, MV, Bimota and most Yamahas in Black, Red, Gold, Silver and Blue £99 Ducati Crankcase Breather Valve Black, Red, Gold, Silver and Blue, £30 CNC Machined Anodised Brake Fluid Reservoir caps in Black, Red, Gold, Silver and Blue £24 - £36 Axle crash bungs in Black, Gold, Silver and Blue £57, front for most Ducatis, rears for some too
Andy, I'm in the throes of loading their products on my website........which is www.solocorse.co.uk Its a mess at the moment but building slowly......you can always ask me...I keep some clutch covers and pressure plates in stock along with other bits and bobs from them, as well as IRC Radial Master Cylinders, Frando calipers, SBS and Performance Friction pads, Wilbers suspension products, Talon sprockets and many other things.....
Thanks David!.........and for the reply to my email, we've talked before so i'm familiar with Solo Corse....just thrown by the forum 'nic' ;-)
