Bike starts fine. The Ignition coil codes appear occasionally. Following a run P0351 will appear and is displayed on the following diagnostic software as follows: JPdiag: Ignition coil A primary and secondary circuit malfunction, Guzzidiag: P0351 to high and Tuneecu: Ignition coil 1 circuit malfunction. P0352 has only popped up once once. The bike farts occasionally through the front intake when in slow traffic. The bike is fine at high revs. I would be very appreciative if Forum Members can offer any ideas as to why this is happening.
its an ignition error. usual checks, plugs, connections to coils or water ingress. maybe even the coils themselves. it is also a coil driver error within the ECU but unlikely.
i had an S4 (know its a different engine) which started running on 1 cylinder at low revs. The font coil was corroded because of all the crud from the front wheel hitting it i suspect yours is on its way out
