Coolant ... Doubts ..
Discussion in 'Ducati General Discussion' started by Ayr Barnabé, Aug 23, 2016.
  1. Hi ladies , someone could tell me what to do with the coolant ???
    I don't know what the old owner put there and I want to depleting the reservoir and refil it with fresh Motoccol + Moccol ( temperature in Brazil is complicated .. very hot ).
    I need to remove the water pump to do this ? Is a Hyperstrada 821 .
  2. No need to remove your water pump, you'll have a drain plug similar to the picture below to allow you to drain your coolant.
    #2 Robarano, Aug 23, 2016
  3. Thanks , Robarano.:blush:
  4. I've looked all over my 1100 hyper and cannot find that plug .....
  5. Nice try :D It's in the same place as the Monster 1100 on your bike. :Woot:
    • Nuke Post Nuke Post x 1
  6. I found the plug ... but to avoid air bubbles inside the sistem ???
    Wich the correct way to do it ??
  7. I have found that putting the bike on the sidestand (This puts the radiator cap at the highest point) and squeezing your coolant hoses a few times whilst filling with antifreeze gets rid of most air. Then start the bike for a short while (maybe 1 min), stop the engine, remove the radiator cap and top up again. DO NOT remove the radiator cap if the engine is hot, wait until it cools.
  8. OK I'll do it
