Hi all have a small leak form the water pump housing and can’t seam to see a gasket listed on the parts diagram? Anyone any advice on what gasket and coolant to use?
There’s no gasket as such. It’s sealant. Threebond 1215 is the factory spec. Coolant should be a red/pink colour to indicate it’s OAT organic type. Doesn’t need to be any particular brand, but the spec. It’s pretty much standard across the board now. You can get it from Halfords etc.
