Corner Speed
Discussion in 'Ducati General Discussion' started by stevebetts, Nov 3, 2016.
  1. Met Neil at Corner Speed today.
    Top bloke!
    Very thorough.
    Did a recall job on my 899.
    Also looking into my coolant leak situation.
    Highly recommended!
  2. what was that if you dont mind me asking?
  3. It's the seal on the back of the clutch slave. There is a new plastic spacer that houses an O ring seal.
  4. Wish I lived further North and could make use of Nelly's expertise.
  5. Nothing anything bad said about the guy or the place. That tells you all you need to know :)
  6. will be interested to hear what he's going to say re: coolant leak - i had same problem
  7. Had same problem.......does that mean you don't now?
  8. well, it sort of been fixed by my dealer... but now and again i get odd drop of coolant on the floor
  9. What did they do?
    As far as I know, it requires a new water pump to solve the issue.
  10. What was the recall?
  11. See post number 3
