2010 848 engine rebuild Does anyone know any of the following please. Not in the manual and Ducati not very helpful. 2010 Ducati 848 Need crank shaft service limits (E.g. crank run out) Crank shaft big end outside diameter min and max measurements Con rod big end - internal diameter min and max measurements Big end Bearing oil clearance min and max
